Replacing A Single Switch With 3 Way Switch Using Old Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 03:47 PM   #1
Replacing a single switch with 3 way switch using old wiring
I need to have switches at the top and bottom of my basement steps. Currently there is just a switch at the top, with power coming from the light. I want to install a second switch at the bottom, but I do not have access to the first switch to add an additional wire between them. Can I use the green ground wire in place of the red traveler wire and ground each of the original switch to the box? Do I have to have a ground wire on the switch if the light itself is grounded?
I tried to add an additional wire, but do not have wall access to do so.
Thanks you,
Chris
chriscam75 is offline   Reply With Quote
Old 02-17-2009, 04:04 PM   #2
The green wire is unusual for residential wiring. Is this a conduit and wire system (Chicago)? If so, you can pull more wires in the existing conduit.
Make access or research wireless switching.
Anothe option would be to install a motion detector that would see you coming up or down.
220/221 is offline   Reply With Quote
Old 02-17-2009, 07:06 PM   #3
joed's Avatar
Rewards Points: 11,998
The green wire can not be used anything but grounding. Find another way.
Old 02-17-2009, 09:15 PM   #4
12 year IBEW member
go to home depot/ lowes they should have an add on three switch that is wireless the main switch would cover exsiting and the wirelss switch would go at the bottom.
heavyduty is offline   Reply With Quote
Tags
3-way switch , no ground
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
