Replacing A Single-pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 10:39 AM   #1
Replacing a single-pole switch
I have a broken single-pole switch that controls a closet light, but when I pulled it out of the box I found myself a bit puzzled by the wiring. There is one black wire coming off the top screw (which goes to the fixture), but on the bottom, there are two black wires--one coming off the bottom screw and one coming out of the slot in the back. Obviously one is the line, but I can't figure out what the other one is and don't want to swap out the switch until I know what's going on.
This seems like it should be easy, so my apologies if I'm just missing something obvious....
leighton is offline   Reply With Quote
Old 01-21-2011, 10:45 AM   #2
Licensed Pro
The bottom wires are a constant hot in and a constant hot out, the top wire is the switched hot to the light. When you replace the switch, connect the two bottom wires together with a 6in piece of the same gauge wire (pigtail) using a wire nut or Wago-type pushin connector. Connect this short pigtail to the bottom screw of the switch. Connect the other, single black wire to the top screw.
Old 01-21-2011, 10:52 AM   #3
Great. I thought it was something like that but didn't want to pigtail the two until I was more certain. Thanks.
Single Pole Switch is "Hot" to the Touch mbaudler Electrical 7 12-15-2010 12:28 PM
basic question - single pole switch in a 3-way setup dbpass Electrical 10 09-07-2010 06:29 PM
3 way, 4 way, Single Pole/3-Way Combinations slash5bmw Electrical 5 06-22-2010 08:21 AM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
Convert single pole switch to a 3 way! Wildie Electrical 19 05-13-2010 11:20 AM
