Replacing Single Ceiling Cylinder Light With Double Ceiling Cylinder Light In Kitchen - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 06:53 PM   #1
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen
I'm currently replacing my single ceiling cylinder light over my kitchen sink. I bought a double ceiling cylinder replacement. When I removed the single light it had the standard one white wire, one black wire and one ground wire attached. So I unattached them and continued on.
I open the box of the new light and discover one grounding wire, two white wires and two black wires.
My question is can I attach the two white wires to the single white souce wire? and the same for the black wires? Using the (ok I'm not an electrician so don't know the names of parts so well) twisty caps that were used previously...
Any help is appreciated. Thanks.
Travlr234 is offline   Reply With Quote
Old 06-28-2009, 06:58 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Yes, you can connect the 2 white fixture wires to the supply white, the 2 black fixture wires to the black supply. Be sure to connect the supply ground (bare wire to the fixture). I would get some new wire nuts to make the connection.
Old 06-28-2009, 06:58 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Yes. They are called wirenuts.
Old 06-28-2009, 07:01 PM   #4
Wire nuts. I'll keep that in mind. Two new wirenuts came with the new light. I'll switch over to them. Thanks for the quick reply!
Old 06-28-2009, 07:52 PM   #5
Worked just fine. the lights are up and the wife impressed...well at least marginally
Old 06-29-2009, 09:14 AM   #6
jbfan's Avatar
Rewards Points: 142
Good Job!
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
Floor height issues when replacing double layer of laminate floor in kitchen notenoughtime Flooring 1 05-16-2009 07:22 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 01:27 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
