-   -   replacing single ceiling cylinder light with double ceiling cylinder light in kitchen (http://www.diychatroom.com/f18/replacing-single-ceiling-cylinder-light-double-ceiling-cylinder-light-kitchen-47684/)
Travlr234 06-28-2009 06:53 PM
I'm currently replacing my single ceiling cylinder light over my kitchen sink. I bought a double ceiling cylinder replacement. When I removed the single light it had the standard one white wire, one black wire and one ground wire attached. So I unattached them and continued on.
I open the box of the new light and discover one grounding wire, two white wires and two black wires.
My question is can I attach the two white wires to the single white souce wire? and the same for the black wires? Using the (ok I'm not an electrician so don't know the names of parts so well) twisty caps that were used previously...
Any help is appreciated. Thanks.
rjniles 06-28-2009 06:58 PM
Yes, you can connect the 2 white fixture wires to the supply white, the 2 black fixture wires to the black supply. Be sure to connect the supply ground (bare wire to the fixture). I would get some new wire nuts to make the connection.
jbfan 06-28-2009 06:58 PM
Yes. They are called wirenuts.
Travlr234 06-28-2009 07:01 PM
Wire nuts. I'll keep that in mind. Two new wirenuts came with the new light. I'll switch over to them. Thanks for the quick reply!
Travlr234 06-28-2009 07:52 PM
:thumbup: Worked just fine. the lights are up and the wife impressed...well at least marginally :wink:
jbfan 06-29-2009 09:14 AM
Good Job!
