-   -   replacing range with cooktop and oven (http://www.diychatroom.com/f18/replacing-range-cooktop-oven-119710/)
diy-diy 10-10-2011 02:51 PM
Hi,
I plan to renovate my kitchen and thinking to replace my almost 25y. old electical range (whirpool) with a cooktop and wall oven. Ideally, I want oven to be mounted in the different spot. Do I need another circuit (a new wire from circuit breaker panel) or can I just supply both new cooktop and wall oven from the same existing outlet i.e use longer cable for oven from it's new place). Current range uses 40A breaker and a larger 4 wire plug (just like shown here)
Thanks,
Aniva
mpoulton 10-10-2011 02:57 PM
You generally need a new circuit. Most ovens and cooktops specify that they require a dedicated circuit with a specific breaker rating.
diy-diy 10-10-2011 07:18 PM
wiring cost
how much can it be, I can probably pre-wire but I think I can't connect myself inside the breaker panel so I need an electrician...
