Replacing Pull Chain Switch In A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 03:31 PM   #1
j_sun's Avatar
Replacing pull chain switch in a ceiling fan
Hi,
One of my boys decided to play Tarzan on their fan speed control pull chain and ripped it clean out. I took it apart and got the same 4-wire replacement switch at lowes. Here's my problem; the replacement switch is too big to fit in the fan.
I went back to Lowes and they have a 3 wire switch that is much smaller and will fit in the housing. My question is can I use the 3 wire switch and just hook up the high and medium setting wires to the switch and leave the low speed wire disconnected? I'm assuming these switches are just single pole, multie throw setups. Is this correct or are they more intricate than that?
Any insight appreciated!
Jason
j_sun is offline   Reply With Quote
Old 02-18-2013, 03:35 PM   #2
j_sun's Avatar
FYI - normally I'd ohm out the original switch to figure this out but it was split in half when the boys broke it.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Wiring ceiling fan from end of run switch ledergoster Electrical 5 07-08-2012 08:59 PM
Electric- ceiling fan replacement should have been easy... michaelwil Electrical 2 05-19-2012 03:07 PM
Installing a pull chain ceiling fixture safron Electrical 16 08-22-2011 05:13 PM
how to replace pull chain switch on ceiling fan lights carolraine Electrical 1 07-25-2011 06:38 AM
