Old 06-25-2009, 05:27 PM   #1
Replacing an oven install
I'm replacing an oven in my house. It's a built in double oven. Before I buy the new one I wanted to check the electrical connection. The existing connection is a 50 amp double breaker. I have 3 wires going to the oven. Both the neutral and the ground connect to the unshielded wire. Whirlpool says that the connection must be 30 or 40 amp and I can use 3 or 4 wire connection but I have 50 amp is that OK??
Models rated from 7.3 to 9.6 kW at 240 volts (5.5 to 7.2 kW
at 208 volts) require a separate 40-amp circuit. Models rated
at 7.2 kW and below at 240 volts (5.4 kW and below at
208 volts) require a separate 30-amp circuit.
liquidvw is offline   Reply With Quote
Old 06-25-2009, 05:39 PM   #2
Electrical Contractor
You can leave the wire and just replace the breaker to a 40 amp breaker.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-30-2009, 11:59 AM   #3
A follow up question as I'm now just getting around do doing this project. The wire is 6 gauge AL. It was connected via wire nuts to my old oven. The new oven has a whip that is 10 gauge copper. I don't think these wire nuts will fit over both wires. With that said, is split bolts the best way to go. If so what's is the proper wrapping procedure and what type of tape?
Also, would Polaris connectors be a better choice?
Thanks in advance.
Dave
Old 10-30-2009, 12:25 PM   #4
Licensed Pro
Are you sure it is Al? Older wire has a tinned surface that looks like Al, but if you look at the cut ends, you will see it is copper.
If it is Cu, I would use the large blue wirenuts.
If it is Al, you will need to use a connector that is approved for a Al-Cu splice, which may be a split-bolt or a set screw type connector.
Old 10-30-2009, 01:24 PM   #5
Im pretty sure its AL. The cut ends are AL and the wire says AL on it. The house was built in 1997. Thanks for the reply.
Old 10-30-2009, 08:12 PM   #6
Blue wire nuts.
220/221 is offline   Reply With Quote
Old 10-30-2009, 08:36 PM   #7
" Euro " electrician
Originally Posted by 220/221 View Post
Blue wire nuts.
For Alum to Alum connections ?
Merci.
Marc
Old 11-09-2009, 03:34 PM   #8
I ended up buying the polaris connectors. They were expensive but real easy to install.
http://www.polarisconnectors.com/370...L_EXTRA_IT.pdf
More On This Topic
Making jewelry is a fun hobby that lets you make great accessories for yourself or give away exquisite gifts to your loved ones. To get started, you need to know how to find the right wire gauge for your project. If the wire is too big or too small, it... Read More »
In this step, we're going to talk about the proper procedure for remounting your license plate and your last rear lamp. Your license plate bracket is going to mount through the mounting holes for your lamp. As you can see, we have some studs here on the... Read More »
Differences in Wire Gauges
Differences in Wire Gauges by Expert Village
Hello! This is Ross on behalf of expertvillage.com. Wire thickness is measured in gauge. The bigger the number, the smaller the wire. For instance, house wiring is commonly 14 gauge or sometimes might be 12 gauge if it needs to handle more current and it... Read More »
On behalf of Expert Village my name is Tom Roland and we are at Cottonwood Motor Sports and I am here to tell you about doing a service on a Polaris Quad and this if fairly representative of macho, many of them. Right up here there is this red spark plug... Read More »
On behalf of Expert Village, my name is Tom Roland and we're Cottonwood Motorsports and I'm here to tell you about doing service on a Polaris Quad and this is fairly representative of much of many of them. Alright, on the transmission on the Polaris 500... Read More »
SCARY oven fire! Why did it burn? Beth777 Appliances 31 11-25-2009 01:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 5 11-26-2008 07:30 PM
Oven Building sinr98 Electrical 3 09-14-2008 12:43 AM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 06:05 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
