Replacing An Outside Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 12:39 AM   #1
replacing an outside breaker box
hello; we live in a trailerhouse with our main breaker box on the electric pole about two feet under the metor box.. we need to replace the single line box with one that can handle up to four lines for our water well pump motor, our freezer and ac unit, and an outside plug in for an electric fence power box... what kind of breaker box do we need to get to replace the existing one?
jensage58 is offline   Reply With Quote
Old 07-03-2012, 05:52 AM   #2
This sounds like a temporary electrical installation and probably should not be expanded. The panel should be inside. I recommend you consult an electrician.
Old 07-03-2012, 10:19 AM   #3
Rewards Points: 126
Whats a "line"?
Old 07-03-2012, 10:24 AM   #4
Licensed electrician
Rewards Points: 1,472
Sounds like it might just be a disconnect and the OP is looking for a small panel to feed several new circuits and the existing house panel.
Old 07-03-2012, 01:30 PM   #5
We have a house breaker box .. INSIDE.. the one on the pole is a Main Breaker Box with one large breaker in it to shut power off to the Whole trailer... what we need is one with multi breakers for large appliances and our water well motor...
Old 07-03-2012, 03:36 PM   #6
Sparky
Rewards Points: 510
The best option would be a meter combo panel. Similar to this.
Techy is offline   Reply With Quote
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
replacing main breaker box rebelbull Electrical 8 01-18-2012 01:20 PM
Replacing two switches on one plate, each wired to a different breaker. bcainjr78 Electrical 4 10-11-2011 07:23 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
