Replacing Outlets: Pigtail, Or Don't Pigtail? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 01:01 PM   #16
Res Ipsa Loquitur
Can't speak of Leviton's GFCI's but I like the Cooper product line- in my area Lowes carries that brand, HD carries Leviton.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 05-05-2009, 02:19 PM   #17
We have Lowe's and Home Depot in my area, and we also have Menard's, who carries Pass & Seymour.
After much DIY experimentation at my house and my dad's, I prefer the back-and-side wired, self grounding P&S "premium" receptacles. They are almost $2 each, but they're so much nicer than the 40 centers, and, I think, marginally nicer than the similarly priced "premium" receptacles from Leviton and Cooper.
Pass & Seymour GFCI outlets are also about 1/4 inch shallower than the Cooper and Leviton GFCIs. (But they are slightly wider; there's less room between the side terminals and the sides of the box before...oops!)
thegonagle is offline   Reply With Quote
Old 05-05-2009, 02:50 PM   #18
both methods are approved, but pigtailing is really the right way to do it. Back-stabbing is faster, and when you're doing hundreds of them, than time makes a difference to a big contractor.
If you're just doing a few for yourself, at your own home, then hands down I believe you should just pigtail it. but that's just my 2 cents...
31b is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
replacing old outlets and switches Nailpounder Electrical 7 04-28-2008 09:36 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
