Replacing Outlets With Granite Installed - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 08:24 PM   #1
Replacing outlets with granite installed
I had granite installed and am replacing all the electrical myself. I purchased extenders but they don't seem to be working because the granite was cut too tight. Since all the wires are covered up inside the back of the receptacles do I need to use the extenders? I bought longer screws and it works fine but I was just concerned with the idea that there is nothing surrounding the outlet other than granite and the old box if I don't use the extenders. There is only a slight bit of particle board that shows through on the side. Any thoughts would be appreciated
Missmosey is offline   Reply With Quote
Old 05-03-2009, 08:33 PM   #2
Bigplanz's Avatar
Rewards Points: 912
What is an 'extender'?
Bigplanz is offline   Reply With Quote
Old 05-03-2009, 08:38 PM   #3
box extender usually 1/4-1/2"
Old 05-03-2009, 08:48 PM   #4
It is a plastic box the same dimensions of the original electrical box in the wall and will normally slide into the area where the granite is you then screw the outlet into that. I believe I got mine at Lowes it would have been great had the granite been cut to size.
Old 05-03-2009, 08:50 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
I use Arlington BE-1's and BE-2's for this.
Speedy Petey is online now   Reply With Quote
Old 05-03-2009, 08:55 PM   #6
Excellent they are less detailed than the ones I have and seem like they would do a better job since they are flexible. Thanks so much
Old 05-03-2009, 09:08 PM   #7
In a typical installation, since granite is not combustible, no extensions necessary......but why would there be particle board behind the splash???
220/221 is offline   Reply With Quote
Old 05-03-2009, 09:22 PM   #8
For reference:
314.20 In Wall or Ceiling.
In walls or ceilings with a surface of concrete, tile, gypsum, plaster, or other noncombustible material, boxes employing a flush-type cover or faceplate shall be installed so that the front edge of the box, plaster ring, extension ring, or listed extender will not be set back of the finished surface more than 6 mm (1/4 in.).
In walls and ceilings constructed of wood or other combustible surface material, boxes, plaster rings, extension rings, or listed extenders shall be flush with the finished surface or project therefrom.
Old 05-03-2009, 09:30 PM   #9
It is minimal just ever so noticeable between the original box and granite. Will look into the Be-1's or 2's mentioned.
Old 05-03-2009, 09:37 PM   #10
Wow, they only give you 1/4 slack there?
314.20 get's violated more often than Paris Hilton.
Granite backsplash over beadboard? Asil65 Building & Construction 10 03-23-2009 12:02 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
Electrical outlets and Granite backsplash, how? section8 Remodeling 6 01-08-2007 07:55 AM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 09:53 AM
