Replacing Outlet - No Ground Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 08:10 PM   #16
Rewards Points: 129
RESULTS:
When I touch the red probe to the HOT wire, and black to the other wire (Cold?), it reads 120V on the meter.
When I touch black probe to the other wire (Cold?), it reads about 50V on the meter. What does this mean?
The socket housing box is very dusty, etc.
Mathlete is offline   Reply With Quote
Old 12-17-2011, 11:59 PM   #17
Rewards Points: 129
When using a voltmeter on a car, you are looking at DC, which is the right side. Correct?
Old 12-18-2011, 02:29 AM   #18
Licensed electrician
Rewards Points: 1,742
The V= is for DC voltage.
Can I ground an outlet via a cable jack? OhNevermindMe Electrical 7 04-15-2010 10:06 PM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 12:42 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
