Old 05-06-2011, 11:44 AM   #1
Replacing out of code ground wires in an older home
I just purchased an older home (circa 1955) which has a fuse box. I'm working with a licensed electrician to get an estimate to switch out the fuse box for breakers. However, I've also discovered that the house has a ground wire to all of the outlets that is not up to code. What's the best, easiest way to replace that wire without taking out my drywall?
Ozzie2341 is offline   Reply With Quote
Old 05-06-2011, 12:12 PM   #2
I'm in the same boat you are right now but my box has already been convereted to breakers... Just no ground wires...
ReiKo is offline   Reply With Quote
Old 05-06-2011, 12:29 PM   #3
I=E/R
a7ecorsair's Avatar
You need to tell us if the wiring is cable (romex) or wire in conduit. You also mentioned that there is a ground wire but not up to code so I'm assume this means current code. Is your wiring copper? Is the ground wire not up to code because it is one size smaller than the conducting wires?
a7ecorsair is offline   Reply With Quote
Old 05-06-2011, 12:59 PM   #4
joed's Avatar
If you are referring the the ground wire on each branch circuit then you don't have to do anything. It will be fine as it is. The grounding system for the new panel will need to be current code however.
Do not PM with questions that can be asked in a forum. I will not respond.
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
How to connect ground wires? Iva Electrical 3 10-29-2010 01:13 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
