Replacing Old Vainty Light Without An Electric Box - Safe? Doable? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 07:50 PM   #1
Replacing old Vainty Light without an electric box - Safe? Doable?
We removed our old vanity light to find no electric box. The light I ordered requires a box. I'm wondering if I can install the bracket directly to the wall and not install a box?
I can definitely do it but I'm worried it's not safe? But our old light didn't have a box, so why not?
Installing a box is not something I cannot do myself. There were 2 holes in the wall when we removed the old light and I can see the stud but not sure if I could mount a box across the studs. Too advance I think for me.
2 pics attached the wall now and the new light.
Please help!
Thanks!
Replacing old Vainty Light without an electric box - Safe? Doable?-screen-shot-2011-12-22-8.47.44-pm.jpg   Replacing old Vainty Light without an electric box - Safe? Doable?-photo-2.jpg
Dow61 is offline   Reply With Quote
Old 12-22-2011, 07:52 PM   #2
last pic was upside down sorry
Old 12-22-2011, 07:57 PM   #3
Licensed electrician
Rewards Points: 1,474
You need to install a box to properly contain the splices between the cable and the fixture wires.
Old 12-22-2011, 08:00 PM   #4
thanks for the quick reply.
any advise on how? I know it's a broad question, but any help is appreciated.
Old 12-22-2011, 08:05 PM   #5
You could cut out the drywall and install a wood brace and use a 1/2" deep pancake box. An old work box should also be able to support that fixture.
An old work box has swing-out wings that grab the back of the drywall.
Old 12-22-2011, 08:57 PM   #6
I just replaced the light in my bathroom and had the same problem. I did what jim port suggested and put some plywood strips inside the wall and screwed a 1/2 inch pancake box to them.
Old 12-22-2011, 09:41 PM   #7
Is this the old work box Jim? http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 12-22-2011, 09:45 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Originally Posted by Dow61 View Post
That is an old work box, but you want a round one.
Old 12-22-2011, 09:51 PM   #9
Ok I'll use this one
And all I need is this? Right? Do I need to drill a place for the wires to go through it?
Thanks again!
Old 12-22-2011, 09:54 PM   #10
jbfan's Avatar
Rewards Points: 386
Thats the one, and it will have tabs that you place the wire into.
Old 12-22-2011, 09:55 PM   #11
Missouri Bound's Avatar
I'll be the devils advocate.....are you sure the new fixture needs a box? Most do not, as the fixture enclosure satisfies the "connection within a box" qualification....I'm just sayin'
Old 12-22-2011, 09:55 PM   #12
Something else that may be of use.
It screws into the stud, I feel like it's much more secure then the drywall braces. Not to mention it's rated for a 70lb ceiling fan
http://www.aifittings.com/catalog/fa...ne-box/fbs1423
PLC has them, but they require a min $25 order
http://www.plccenter.com/Buy/ARLINGTON/FBS1423
This would allow you to center the box on the stud, it may or may not work for you depending up where your center point is.
http://www.platt.com/platt-electric-...px?zpid=164316
Good luck!
fuzzball03 is offline   Reply With Quote
Old 12-22-2011, 10:04 PM   #13
@Missouri - I have no idea if it needs a box. In my 1st post I explain. Let me know your thoughts.
@fuzz - the stud is too far to the right at the hole on the right
@jbfan - great thanks!
Old 12-22-2011, 10:19 PM   #14
Rewards Points: 6,652
A Smart Box would work. Otherwise, since this is drywall, I would just remove a section install a regular box, then install a patch over, since that section that is there is already well torn up, and would take some effort to make it look somewhat decent with a patch, but it would not be perfect.
Old 12-22-2011, 10:21 PM   #15
You mentioned the light you ordered....did you get it yet? Post a picture of the fixture if available. So many vanity lights are of the strip variety, with a metal can that fastenens to the wall, with a k/o for the wire. No box needed if that is the case.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Replacing a 30" Electric Drop-in Range SLC3271 Appliances 5 06-10-2014 09:22 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Replacing Ceiling Fan without light w/ fan + light BSponz1 Electrical 7 01-30-2011 04:57 AM
Replacing a Water Heater with Electric One 2031pratt Plumbing 3 12-26-2008 09:17 AM
