Replacing Old Receptacles With New Decora On A 3 Way Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 09:11 AM   #1
replacing old receptacles with new decora on a 3 way light switch
I am trying to replace two receptacles that work with 2 light switches. The old round receptacles were upside down in the room and are supposed to be used with lamps. I bought 2 switches that were for 1 light and 2 locations. I was told by the guy at Lowes that the receptacles that I use are standard, only that I need to break off a metal tab between the outlets in order for them to work. I did this and my receptacles stay hot - they will not turn off with the light switches. What am I doing wrong?
furniture man is offline   Reply With Quote
Old 03-06-2011, 09:17 AM   #2
Electrician
Rewards Points: 760
Did you break off the silver or brass tab.
darren is offline   Reply With Quote
Old 03-06-2011, 09:19 AM   #3
I broke off both tabs - one on each side
Old 03-06-2011, 09:23 AM   #4
joed's Avatar
Rewards Points: 11,516
IF the receptacle is only half switched then you break off the gold tab. If the both plugs are switched on the receptacle then you don't break off any tabs.
Hi, new here and have a question about light switch in bathrooms Tazznum1 Electrical 2 01-26-2011 09:31 AM
Replacing switch -- TOTALLY CONFUSED! JGLA Electrical 1 11-14-2010 03:33 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
