-   -   replacing old receptacles with new decora on a 3 way light switch (http://www.diychatroom.com/f18/replacing-old-receptacles-new-decora-3-way-light-switch-97394/)
furniture man 03-06-2011 09:11 AM
I am trying to replace two receptacles that work with 2 light switches. The old round receptacles were upside down in the room and are supposed to be used with lamps. I bought 2 switches that were for 1 light and 2 locations. I was told by the guy at Lowes that the receptacles that I use are standard, only that I need to break off a metal tab between the outlets in order for them to work. I did this and my receptacles stay hot - they will not turn off with the light switches. What am I doing wrong?
darren 03-06-2011 09:17 AM
Did you break off the silver or brass tab.
furniture man 03-06-2011 09:19 AM
I broke off both tabs - one on each side
joed 03-06-2011 09:23 AM
IF the receptacle is only half switched then you break off the gold tab. If the both plugs are switched on the receptacle then you don't break off any tabs.
