Replacing Old Receptacle (PICS) - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 05:29 PM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
Replacing old receptacle (PICS)
Double gang with receptacle and switch that controls a light. I want to replace the receptacle, not sure how to wire.
The box has red, white and black coming into it. The red is passing through the switch.
On the receptacle the wires are going into holes on the back rather than secured to the side screws.
Can I remove the red, white and black from behind the receptacle and secure it to the new receptacle on the screws? Red and black on the hot side and white on the bottom neutral side? This will leave one neutral screw empty.
picflight is offline   Reply With Quote
Old 10-25-2011, 05:33 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
If all you are doing is replacing the receptacle then just wire it back the way it was. Or am I missing something?
With the red and black on one side that suggests half of it is switched. If this is so then be sure to break the tab between the two brass screws.
Old 10-25-2011, 05:39 PM   #3
Busy DIYer
picflight's Avatar
Rewards Points: 150
If I break the tab on the brass side, the red won't have power?
Old 10-25-2011, 06:26 PM   #4
Rewards Points: 150
Maybe you aren't explaining something properly. You said you have a black and a red on the brass side. This indicates a split recep. Both black and red are hot. One recept is constant, while the other is switch controlled
Sunny B. is offline   Reply With Quote
Old 10-25-2011, 09:01 PM   #5
Busy DIYer
picflight's Avatar
Rewards Points: 150
No, I said I have black, red and white sticking in holes in the back. As for explanation, I have picture and wiring diagram. What do you think is missing?
Old 10-25-2011, 09:13 PM   #6
DIY staff
Rewards Points: 7,174
By your drawing---the power is simply a carry through to the switch---so no need to remove the tab.
Remove the tape on the old recepticle--make sure the tab is om the old one---
Old 10-25-2011, 09:21 PM   #7
Rewards Points: 6,652
Picflight, holy schnikies. Can you make that picture any more of a macro zoom. Maybe 3240x3240 would be better helpful to the rest of us with failing eyesight.
Old 10-25-2011, 09:56 PM   #8
Busy DIYer
picflight's Avatar
Rewards Points: 150
Greg, I try to make the pics easy for mobile and aol users to download while trying to keep a decent size. I guess I did not do a good job on the latter. Next post, you will see the full size :-)
Old 10-25-2011, 10:20 PM   #9
It is just that it blows out the browser, when it is larger than expected. It would be nice if they would set up the board, so that it resized the photos, so that they did not blow out. BTW, who ever last did that outlet, wasted the electrical tape. I would not doubt that they did the same with the rest of the outlets in the house. Good insurance, but not needed.
Old 10-25-2011, 11:22 PM   #10
Busy DIYer
picflight's Avatar
Rewards Points: 150
The outlets I have opened up so far, none had the tape, this is the first I have seen. This from a mid-fifties home.
Old 10-25-2011, 11:45 PM   #11
picflight, it was not backstab btw (ie wires inserted in the holes on the back, vs. properly secured around the screws).
Old 10-26-2011, 03:04 AM   #12
" Euro " electrician
frenchelectrican's Avatar
I would suggest that you turn the circuit off compelty and pull that tape off and actually see how it hook up to be on safe side and do not take any wires off at the moment until you see the screw colour and the bridge tab[s] is there or been removed.
Merci,
Marc
Old 10-26-2011, 07:17 AM   #13
Electrician
SD515's Avatar
Rewards Points: 504
The OP is saying the switch controls a light. My guess is the black is the feed and the red is the switch leg, power originating at the light box. If that’s the case, leave the bridge tab on the receptacle. Yes, you can use the screws on the new receptacle, they’ll provide a better connection. Yes, black and the red jumper wire on the ‘hot’ side of the receptacle, bridge tab left intact, white on the neutral side. Red jumper to the switch to power it. What I don’t see in the picture is ground wire jumpers from the receptacle and switch to the box.
Kyle
Old 10-27-2011, 03:58 PM   #14
Busy DIYer
picflight's Avatar
Rewards Points: 150
Greg, yes the wires are inserted in the holes and not screwed.
Sd, your review sums up how it is currently wired and how I am thinking of wiring the new receptacle. So it is ok to have one white & black screwed on the lower and the red on the brass side going through the switch?
Old 10-28-2011, 07:05 AM   #15
Electrician
SD515's Avatar
Rewards Points: 504
Yes, upper or lower, doesn't matter as long as the bridge tabs are intact. White on a silver screw, black and the red jumper on a brass screw of their own. The red jumper is suppying power to the switch.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
picflight (10-28-2011)
Trouble replacing a switch / outlet receptacle. Hey BC Electrical 1 05-24-2011 05:40 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 08:32 AM
Help? Motion Sensor receptacle wtu007 Electrical 5 10-12-2009 12:33 PM
Lightswitch No Longer controls Receptacle After Changing It earthad1 Electrical 20 07-30-2009 06:25 PM
replacing an old Electrical receptacle djtjak43 Electrical 3 08-28-2008 07:46 AM
