Replacing An Old Porcelain Ceiling Light Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 02:14 PM   #1
Replacing an old porcelain ceiling light socket
The ceiling appears to be slat and plaster - I know the walls are because I have replaced damaged portions. The porcelain socket appears to be attached WITHOUT a junction box. Could this be right? If so, do I need to install a junction box in order to install a flush ceiling light? If I cut through the slats, how will I attach the junction box?
bellzerr is offline   Reply With Quote
Old 09-29-2010, 03:26 PM   #2
Rewards Points: 320
The lights need a box to mount to. Is there unfinished space above? There are many different mounting options depending on access and the type of cable that you have feeding the light.
teamo is offline   Reply With Quote
Old 09-29-2010, 04:54 PM   #3
Rewards Points: 1,442
Get a metal box about 2-1/2 x 3-1/2 inches at the front and with tabs on the ends of the opening to screw it to the wall.
Mount the box across the slats. cUT Onw aalalasllslatr slat all the way through and cut the slats on each side halfway through which should leave a hole big enough to put the box in and the tabs are screwd onto the slats cut halfway thorough.
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 23 03-28-2014 06:46 AM
ugh, very simple electrical question - installing ceiling light diy'er on LI Electrical 6 02-16-2010 11:23 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-14-2009 12:09 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
