Replacing Old Hood With Over-the-range Microwave - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 10:17 PM   #16
PureCountry's Avatar
I'm installing a over range microwave and have no idea how to do the hardwire .. Help!
PureCountry is offline   Reply With Quote
Old 07-26-2012, 11:03 PM   #17
Licensed electrician
Rewards Points: 1,250
You will install an outlet in the cabinet above the microhood on a dedicated breaker. You will run a 15 or 20 amp cable from the location to the panel and install a new single pole breaker.
Old 07-27-2012, 12:17 AM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by gregzoll View Post
Also sharing with the washer is not code compliant.
Why not? We only need to supply a 'Laundry Circuit' no where is it stated that it is for the washing machine.... with that said, if the loads met the circuit criteria I don't see any violation.
Old 07-27-2012, 12:25 AM   #19
E2 Electrician
Originally Posted by HouseHelper View Post
Since an over the range microwave is also a hood, and it is cord and plug connected, then the circuit supplying it should be an individual i.e., dedicated, branch circuit. (see 422.16(4))
I disagree, a microwave range hood is not what 422.16 (4) is referring to, nor was intended to.
Old 07-27-2012, 10:20 AM   #20
Stickboy,
The laundry circuit is restricted to the laundry area only.
(2) Laundry Branch Circuits. In addition to the number
of branch circuits required by other parts of this section, at
least one additional 20-ampere branch circuit shall be provided
to supply the laundry receptacle outlet(s) required by
210.52(F). This circuit shall have no other outlets.
How would you get around the 422.16(4) requirement? The instructions for the MWH would also call for a dedicated circuit.
Old 07-27-2012, 12:02 PM   #21
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Why not add it to the D/W and disposal circuit?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-27-2012, 04:37 PM   #22
E2 Electrician
Originally Posted by Jim Port View Post
Stickboy,
Jim, you cannot assume the washer is utilizing the required laundry branch circuit. This was my point to begin with when someone said is was a code violation to have anything else on the washing machine circuit.
422.16(4) does not include microwave hoods, only range hoods, there is a difference, and this is why 422.16(4) exists to begin with, also, you cannot assume a microwave hood will call for a dedicated circuit.
With that said, im all for a dedicated circuit, but it seems sheepish for the nec to require such nonsense, since I can buy a standard microwave and place it on my counter and plug it in to any small appliance circuit shared with other appliances...
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
OTR Microwave -> Range hood wiring A for Effort Electrical 2 07-31-2010 11:00 AM
Replacing range vent hood goldbedr Appliances 0 04-12-2010 12:27 AM
Installing a range hood NewHandyman Electrical 1 08-10-2009 10:42 AM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 01:01 AM
