Replacing An Old Electrical Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2008, 03:21 PM   #1
Question
replacing an old Electrical receptacle
I have a friend who has a small pond with a very old outlet for a small pump for the pond. The receptacle, which is above ground on a short post, has three prongs in a circle. He got a new pump which just has the regular three prong plug on it. Can we replace the current circular receptacle with a standard GFI? The old plug says 20 amp, 125 volt on it.
Dennis
djtjak43 is offline   Reply With Quote
Old 08-27-2008, 03:44 PM   #2
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Yes you can put in a standard receptacal there. First turn off power to that circut. Then take out old recep. Put black on gold colored screw. White on silver screw and green or bare on green hexagon screw.
Pudge565 is offline   Reply With Quote
Old 08-27-2008, 04:19 PM   #3
Registered User
Termite's Avatar
Make sure that you install a weather-protected cover on the receptacle so when the pump is plugged in, water won't get in the receptacle.
Also, either install a GFCI receptacle outdoors or a GFCI breaker at the panel feeding the circuit. Without GFCI protection, it is an unsafe condition.
Old 08-28-2008, 07:46 AM   #4
When is fishing season?
CowboyAndy's Avatar
Also make sure that the new recep is rated for true 20 amps... it will have a t-shaped prongs.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 02:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 11:36 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
20A or 15A receptacle ejlog Electrical 3 02-21-2005 06:29 PM
