Replacing An Old Electrical Panel (w/out Ground Bar) - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 01:10 AM   #1
Rewards Points: 18
Question
Replacing an old electrical panel (w/out ground bar)
We just bought a house. It was built around 1960 and it looks like it has not been re-wired. The panel was possibly updated, but it still looks pretty old and I don't see any ground bar in it. Here is a picture of it:
I know that *some* of the outlets seem to be grounded (ground test on outlet passes), but some of outlets are not grounded. So, I assume there is some sort of grounding done, although I do not see it in the panel.
The main service entrance has a different panel on the outside wall of the house. The meter is also located in that panel. That main panel has a two circuit breakers, one for 100 Amp (main house), another for 50 Amp (AC).
So, it looks like the electrical panel in the house is sort of a sub-panel. It want to replace it with a new panel and use AFCI breakers wherever needed (based of NEC 2008). I also want to add a 60 Amp sub-panel to garage that is connected to this panel in the house.
My questions:
(1) Where is the grounding? How can I test that the panel box itself is grounded? When I replace the panel, what will I do with the ground bar? (I might eventually end up a new re-wiring project). Should I add new ground rods and connect the new panel to those?
(2) I see that some of the neutral wires were shared. Is this acceptable? Two hot wires go to different breakers, but they share a neutral wire.
yilmazma is offline   Reply With Quote
Old 12-13-2012, 07:07 AM   #2
That does look like a sub-panel, and I see no grounds at all. I would definitely replace and bring up to code. Have a local expert have a look-see.
Old 12-13-2012, 07:17 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If this sub is piped with metal conduit, which it appears to be, then that conduit is the ground path. Nothing would be needed to be done code wise. You may want to Google FPE and house fires tho.
Old 12-13-2012, 07:27 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Not all panels need a separate ground bar. Main panels use the neutral bar(s) for both neutrals and equipment grounds.
This sub-panel may not have needed a separate ground bar. Maybe the circuit cables did not have a grounding conductor. Maybe they used AC cable. Maybe things are in pipe.
Equipment grounding can come from several different sources. It is not always a bare copper wire.
It IS a sub-panel
It may have an equipment ground, it may not. This cold be a pipe that the feeders were run in. Testing for it is is not nearly an exact science. It is more of a visual check. If there is an equipment ground path then you would just screw a ground bar to the panel box.
Grounding electrodes have NOTHING to do with equipment grounding. They originate at the main panel only and serve a very different purpose.
Yes, this is very typical and perfectly fine.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 12-13-2012, 10:45 AM   #5
Rewards Points: 240
That panel is an FPE Stab-Lok. It is a known fire hazard. Replace it ASAP.
fa_f3_20 is offline   Reply With Quote
Old 12-13-2012, 11:58 AM   #6
Rewards Points: 18
Thanks everyone for your responses. I will have it replaced ASAP.
Help New Addition Electrical Sub Panel/Load RISurfer Electrical 19 07-30-2012 08:34 AM
ceiling fan light issue after replacing electrical panel texan206 Electrical 3 04-22-2012 12:33 AM
New detached garage with sub and ground, house has no ground at panel italie Electrical 9 09-12-2011 03:43 PM
Service panel ground downunder Electrical 13 05-13-2011 05:46 PM
Replacing an exterior electrical panel shadetree12 Electrical 13 11-30-2008 11:26 PM
