Replacing Old 2 Wired A/c T-stat With Hvac Honeywell Rth2310 - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2010, 01:10 PM   #1
replacing old 2 wired a/c t-stat with hvac honeywell rth2310
i just bought a 35 yr old home and the t-stats for the ac and heating are seperate, also, heating unit was disconnected to install gas heaters(no t-stat involved.) I purchased a honeywell rth2310 to replace old sear's t-stat. When i removed the cover there is only 2 wires r and w. I connected r to Rh and Rc jumper and w to w, but it not working properly. do i have the connection wrong?
sbox is offline   Reply With Quote
Old 05-15-2010, 02:52 PM   #2
Electrical Contractor
kbsparky's Avatar
If this is for cooling operation, you have to connect the 2 wires to the RC and Y terminals.
The W terminal is for "heat" No jumper is required between RH and RC.
-KB
'HELP! Replacing Honeywell T4039 with Honeywell TB6575A1000'‏ whitemamba HVAC 28 02-14-2010 09:27 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Replacing an OLD Honeywell thermostat Parent HVAC 1 11-21-2009 09:47 PM
Replacing a switch wired in series? bmoorhouse Electrical 11 04-19-2009 08:04 PM
Replacing HVAC Thermostats handy man88 Electrical 4 11-19-2007 02:43 PM
