Replacing Mains Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2007, 03:54 PM   #1
Rewards Points: 150
replacing mains wire
My mains coming in from the outside seem to have a splice inside the breaker box, like they were just too short and another piece was put on...
I want to fix this. I have no problem doing it, but I imagine I'd have to break the seal on the meter, open it to open the circuit, and just replace the wires?
Should I call the electric company or is this just upto me since it's on my side of the meter?
elementx440 is offline   Reply With Quote
Old 05-09-2007, 04:38 PM   #2
jproffer's Avatar
Rewards Points: 706
You should call the power company to disconnect the power at the drop*, and pull the meter.
* VERY IMPORTANT to have it disconnected at the drop (the wire coming from the transformer that is usually the POCO's responsibility) since you won't want the lines at the top of the meter to be live since you'll be working within 4 inches of them.
jproffer is offline   Reply With Quote
Old 05-09-2007, 04:39 PM   #3
Rewards Points: 150
yeah i was thinking of that, when you go feeding big 'ol thick wires through the hole...
do you think this sort of thing requires a permit or carries any fee from the poco? Just to cut the power so I can replace the 10 foot or so run from the meter?
Hain't we got all the fools on our side?
And ain't that a big enough majority in any town?
-Mark Twain
Old 05-09-2007, 08:29 PM   #4
So Cal Electrician
Send a message via Yahoo to hbsparky
don't break the seal, the POCO can charge you for tampering and can actually have you thrown in jail. Another thing, some of those transformers upstream can throw upwards of 20,000 amps your direction if you short one of those lines out, and at that load, it takes less than a blink of an eye to pretty much melt your body.
Well....Butter my butt and call me a biscuit!
hbsparky is offline   Reply With Quote
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 09:23 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
