Replacing Main Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 01:33 PM   #1
replacing main breaker box
i have to replace main breaker box and was wondering if i can use a QO Panel Circuit Breaker or do i have to use the box that has main breaker in it?
here is the one im wonderinf if i can use http://sutherlands.com/products/product.php?item=665786
or do i have to use one of these
http://sutherlands.com/products/product.php?item=741256
rebelbull is offline   Reply With Quote
Old 01-18-2012, 01:39 PM   #2
Julius793's Avatar
The second link, you need a main unless you happen to have one already.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-18-2012, 01:45 PM   #3
but why do i need a main the one im replacing does not have one?
Old 01-18-2012, 01:46 PM   #4
Julius793's Avatar
Ok is there a main next to the meter?
Old 01-18-2012, 01:59 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by rebelbull View Post
but why do i need a main...
so you can turn everything off at once
Old 01-18-2012, 02:02 PM   #6
im not sure, but by code do you have to have one?
Old 01-18-2012, 02:06 PM   #7
Julius793's Avatar
Yes, why dont you send us some pictures of the panel and meter
Old 01-18-2012, 02:10 PM   #8
Rewards Points: 13,276
By the questions your having to ask you should not be messing with this, hire a real electricion.
Old 01-18-2012, 02:20 PM   #9
Rewards Points: 3,256
To maybe answer your question about why you don't have a main breaker. If your area uses the NEC they allow up to 6 breakers (or switching motions) without a main. If I were replacing a panel I would want a main breaker so I wouldn't be limited in the future.
zappa is offline   Reply With Quote
Pool Main breaker keeps tripping beckyreyes Electrical 12 08-11-2013 05:06 PM
Main circuit breaker's screws hot even with breaker off? darlingm Electrical 13 01-15-2012 12:44 PM
Changing a breaker. Turn main power off first? noone Electrical 18 11-15-2011 08:08 PM
Help? re replacing valves (main & toilet) iya Plumbing 2 06-14-2010 05:54 AM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
