Replacing Low Voltage System/switches - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 05:23 PM   #1
Replacing low voltage system/switches
I've been reading various posts and 'think' I understand this although I have no experience with low voltage lighting systems. Can I replace the old switches (and eventually the entire system) by simply connecting the j-box feed directly to the 120v feeding the transformer (in a new large j-box to accommodate all of these in one spot) and then run wire from the existing switch box (with a new switch) to the fixture j-box?
Thanks for your input.
InNebraska is offline   Reply With Quote
Old 10-04-2012, 07:24 PM   #2
Master Electrician
Rewards Points: 3,874
Not likely, depending upon where the switching relays are located. The 120 volt transformer power line is not the same power that is being supplied to your fixtures. The circuits are probably different depending upon the lighting loads.
brric is online now   Reply With Quote
Old 10-05-2012, 09:58 AM   #3
Thanks brric
Is there anyway to bypass the whole thing other than pulling new line to the main panel?
Question about replacing line voltage thermostat thinksincode HVAC 5 01-12-2012 10:26 AM
Circuit Board Failure due to High Voltage huyer HVAC 5 01-07-2012 05:07 AM
DC voltage from a PCB dave11 Electrical 3 07-20-2010 06:13 PM
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 07:17 AM
Voltage drop fix I discovered... rgsgww Electrical 12 12-09-2008 05:21 PM
