Replacing A Light....wires Crossed???? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 10:30 PM   #1
Rewards Points: 27
Replacing a light....wires crossed????
I bought a new chandalier for our dining room to replace the one that was up when we moved in. I just removed the old one and the hot from the fixture is going to the neutral and the fixtures neutral to the box's hot. Can someone tell me if this would be done for any reason or just an accident? The light has always worked fine previously. What can happen if this is done? Not quite sure what to do.
jailbird371 is offline   Reply With Quote
Old 04-13-2011, 10:36 PM   #2
Rewards Points: 1,514
It will work either way. The incorrect hookup increases the chance of shock if you are not careful changing the lamps and also did not flip off the switch.
The neutral should connect to the wires going to the sides or shells of the lamp socket (easier to accidentally touch) and the hot should connect to the wires going to the centers or bottoms of the sockets.
Old 04-13-2011, 10:37 PM   #3
Rewards Points: 36
Is there only one white wire and one black wire in the box? (not counting the fixture wires)
daveb1 is offline   Reply With Quote
Old 04-13-2011, 10:39 PM   #4
Rewards Points: 27
Yes, plus ground,
Old 04-13-2011, 10:49 PM   #5
There can be other wires in the box, for example continuing to other lights or receptacles, or going to the switch.
Therefore it is important not to undo such other wires when replacing the light fixture here. A simple fixture replacement can turn into a complicated project figuring out what went where if you disconnect all the wires.
Old 04-13-2011, 10:54 PM   #6
Rewards Points: 27
But in my case, since there is only one 14-2 wire coming in, I should just wire it normally. (opposite of what is was)
correct?
Old 04-14-2011, 06:02 AM   #7
Lic Elect/Inspector/CPO
crossed wires
Look at the wires from the chandilier. If one has ribs on it or is silver color that is the neutral, the other should be smooth or copper color that would be the hot. If in doubt that check for conituity from lamp shell to each wire. The one with continuity is the neutral.
NJMarine is offline   Reply With Quote
Old 04-14-2011, 09:10 AM   #8
Rewards Points: 36
I agree with both Allan and Marine. Also if you have an ohm meter I would check for continuity between the white and the ground (with the breaker OFF). Hopefully the original light wiring is the only goofiness. Do NOT connect the ground to the white when you install your new light.
Old 04-14-2011, 12:17 PM   #9
Rewards Points: 27
I wired the new light last night and did it how it should be. black to black, white to white, ground to ground. Seems to be working just fine.
Replacing a chandelier with a recessed light. RyanD General DIY Discussions 5 01-19-2016 10:27 PM
Replacing a light fixture JELLY DONUT Electrical 4 01-20-2015 10:07 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 09:57 AM
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 04:33 PM
