#1 |
wanabie
replacing light switches
I have a box in the kitchen that has 4 switches in it. two of them were bad so I replaced them all.
The old ones did not have a ground wire running to them, so I added one, and grounded them to the box. Is this ok? Also, before hooking up the ground wire, I turned the breaker on to see if all lights worked, all was good. Then I connected the ground, and stuffed everything back in the box, and tried all switches again. One of them popped and flashed, and blew the breaker when I turned it on. I then turned everything off, reset the breaker, and tried again. It worked about 5 minutes, popped/flashed and blew the breaker again. I then pulled the switch out of the box moved some wire around and put it back in, and now it seems to be fine. Everything works. My Questions are...What caused that pop/flash? And, Do I need to be worried about fire in my walls once I leave for work? Thanks |
#2 |
Electrical Contractor
The pop and flash was the ground wire hitting a hot wire.
When you took the switch out and moved it around, you broke the connection between the hot and ground. If it has not tripped agin, you should be fine.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
wanabie
Thanks, That is what my dad said, but he is kind of a hack sometimes.
I wanted to hear it from someone else too. Thanks again |
| Display Modes | |
| Replacing bathroom vanity light bar | AnnieO | Electrical | 2 | 07-28-2010 09:52 PM |
| light switches | Petrafire | Electrical | 2 | 07-12-2010 02:13 PM |
| Wiring diagram for three-way switches with pilot light | SaxTeacher | Electrical | 33 | 03-18-2009 08:11 PM |
| replacing existing light with can light? | mferguson0414 | Electrical | 5 | 01-23-2009 08:45 AM |
| light switches wired in series -- why? | magnolia | Electrical | 2 | 05-11-2008 12:16 PM |
