Replacing Light Fixture With No Ground Wire In Home - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 09:54 PM   #31
Originally Posted by stickboy1375 View Post
As a side note, as long as the AC type wire contains a bonding strip, then you already have a grounding conductor. So most of this conversation is a moot point.
Wow, this sure had been a lively discussion. I want to make sure I'm clear on what I should do, though. Even though stickboy was right regarding interpretation of the code, it looks like I don't need to add the breaker based on the comment above.
Sorry if this sounds like I've asked the same question a hundred times, but can someone confirm that I'll be ok just installing the chandelier?
@electures, this is the main panel, not a subpanel.
panorama is offline   Reply With Quote
Old 09-13-2012, 10:00 PM   #32
Rewards Points: 506
I believe you have yet to confirm the presence of AC cable with bonding strip, in order to get a good answer.
I give this thread 3 1/2 stars. The plot was good, but somewhat predictable, given the cast.
jlmran is offline   Reply With Quote
The Following 2 Users Say Thank You to jlmran For This Useful Post:
electures (09-17-2012), jbfan (09-14-2012)
Old 09-13-2012, 10:20 PM   #33
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Side note to your original post. You need a main breaker. Also,please verify whether or not the wiring to the light is AC?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-14-2012, 07:29 AM   #34
Originally Posted by electures View Post
Side note to your original post. You need a main breaker. Also,please verify whether or not the wiring to the light is BC?
Is it possible that my main breaker is outside the house (single family home) by the meter?
To be honest, I don't know how to tell if the wiring is BC or if I have an AC cable with bonding strip. I have to refer to Google just to understand the questions.
If you can't tell my level of electrical knowledge is very basic. I'm trying to learn as I go along, but I'm starting to think it may be worthwhile for me to have a licensed electrician come out and personally take a look at my set up.
Old 09-14-2012, 07:34 AM   #35
Rewards Points: 6,652
Yes, you will be okay installing it. Could have had it done and probably would have been better to not ask regarding, since now you see how ugly these things get. Hundreds if not thousands of fixtures are working properly without a gfci being inline, and nothing has happened.
If you want that warm fuzzy feeling, install the gfci, but not required, and you are not going to get in trouble not using it.
Old 09-14-2012, 07:44 AM   #36
Rewards Points: 506
That logic is as dumb as saying all the air-bags and seatbelts in all the uncrashed cars of the world are useless.
The Following 3 Users Say Thank You to jlmran For This Useful Post:
electures (09-14-2012), jbfan (09-14-2012), stickboy1375 (09-14-2012)
Old 09-14-2012, 08:31 AM   #37
Code05's Avatar
Rewards Points: 1,104
Greg, Stickboy never said that GFCI was required, he said that it was one option.
The OP has 3 choices.
1. Verify that a grounding method, ie AC, exists.
2. Run a grounding wire/conductor.
3. GFCI protect the circuit.
That is pretty much it. Period.
We have not even discussed the fact that most, if not all, new fixtures require 90C rated insulated wires and that a house wired in 1965 probably does not have them.
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
electures (09-14-2012), stickboy1375 (09-14-2012)
Old 09-14-2012, 08:38 AM   #38
Is 9:30 am too early for a drink?
Old 09-14-2012, 08:45 AM   #39
Code05's Avatar
I had a feeling that you would not like that insulation part.
Old 09-14-2012, 08:45 AM   #40
electures's Avatar
Do you have just a meter socket or is there another box attached to it? Also, post another picture of the meter enclosure and its surroundings, and another picture of the panel showing the wiring entering the box.
As for Gregs post, again he is wrong. The fixture is required to be grounded or GFI protected. Unlike him, I posted the actual NEC requirements not the narrative from the handbook (which is not code).
Old 09-14-2012, 09:09 AM   #41
Do you have just a meter socket or is there another box attached to it? Also, post another picture of the meter enclosure and its surroundings, and another picture of the panel showing the wiring entering the box.).
I'm not sure if there's another box by the meter. I'll check when I get home and will take some photos. Are you asking for two photos of the meter area (outdoors) and one photo of the electrical panel (breaker box -indoors)? There's only drywall around the electrical panel/breaker box, so nothing more to see...I'm guessing you're referring to something else?
I get that now. Thanks.
The Following User Says Thank You to panorama For This Useful Post:
Old 09-14-2012, 09:31 AM   #42
electures's Avatar
Yes, two pictures. If the picture doesn't show the cabling entering the panel, try and get a picture zoomed in of the connectors in the bottom of the box.
Old 09-14-2012, 09:35 AM   #43
electures's Avatar
Hang in there. We will help you and you will get the correct information. But as you can see, we have a few amatures without a clue and too many new visitors associate post count with actual knowledge and experience.
replacing ceiling fixture - hole in ceiling with wire hanging out sunshine1221 Electrical 4 08-20-2012 09:53 AM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Light switch - Taping into ground wire ok? SimpleJack Electrical 2 08-15-2011 07:04 AM
Ground vs. Neutral wire - bathroom fixture Narwal Electrical 4 08-14-2011 08:27 PM
Light fixture needs a ground wire PRedLSU Electrical 4 05-23-2010 09:35 PM
