Replacing A Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2004, 07:14 AM   #1
Guest
Guest
Posts: n/a
Replacing a light fixture
I am a new handyman and I need some help.... I want to change out a bathroom light fixture and need to know how to wire.
The wall outlet has three wires: white, tan, and a copper ground wire. The new fixture has white, black, and a ground wire. Questions are: 1) White to white and black to tan, correct? 2) What do I do with the two ground wires (one from wall, one from new fixture?
I know these are elementary questions but need help. Thanks a lot in advance.
Old 01-19-2004, 08:59 PM   #2
Guest
Guest
Posts: n/a
Thumbs up
Your wiring scheme should work. The best way to be sure though is to get a meter to make sure that the tan is the hot wire and that white is neutral. Connect your ground wires with a wire nut.
Old 01-20-2015, 05:11 PM   #3
Rewards Points: 30
Always good to double check what wire is hot with a multimeter. You can get one at any hardware store and look up a video on YouTube to find out how to use it.
psychoguy42 is offline   Reply With Quote
Old 01-20-2015, 07:27 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what's up with dragging up ancient threads? You registered in 2012 but only have 15 posts, most of them from today. Are you that bored?
Old 01-20-2015, 10:07 PM   #5
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
No.... He's psychoooooo
clw1963 is offline   Reply With Quote
The Following User Says Thank You to clw1963 For This Useful Post:
nap (01-20-2015)
Replacing a light fixture...Help!!! QTCarla Electrical 7 12-16-2012 04:22 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 04:33 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
