Replacing A Light Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 06:46 PM   #1
Replacing a light bulb
I have been having a huge amount of trouble identifying a halogen blown halogen light bulb I need to replace in our oven. I have looked at the bulb, the fixture, the lens, the heat shield, the manual, called the manufacturer, looked at the oven parts list, contacted a third-party parts website and ultimately I believe I know the specs for the bulb, but I feel I need to know the risks of getting it wrong.
I believe the bulb is a 120V, 20W, G5.3 Bi-pin - something similar to this. Note that the image is of a G8 not a G5.3!
I'm not asking for help finding the bulb for sale (although if I can confirm the specs then that would information would be really useful!). Instead I'd like to know:
- What would happen if I put a 120V bulb in a 12V fixture?
- What would happen if I put a 12V bulb in a 120V fixture?
- Can a bulb be rated for external temperature as well as fixture type, voltage and wattage?
94dgrif is offline   Reply With Quote
Old 01-13-2013, 06:54 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
120 volt lamp in 12 volt fixture will not light
12 volt lamp in 120 volt fixture will blow out in a second.
Temperature rating should not be an issue.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
NJMarine (01-13-2013)
Old 01-13-2013, 01:38 PM   #3
Perfect answer! Thank you very much - I'm going to hunt down a 120V bulb and test it out.
replacing vanity light bar with two lights wannadoitmyself Kitchen & Bath Remodeling 4 08-17-2012 03:01 PM
Light Bulb Trickery Kookie Electrical 39 07-29-2012 12:54 PM
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 09:08 AM
Light switch flashed as ceiling light bulb blew myrrh Electrical 5 09-11-2011 06:53 PM
Light bulb in fan goes off and on ilyaz Electrical 2 07-19-2010 10:00 PM
