-   -   Replacing a light bulb (http://www.diychatroom.com/f18/replacing-light-bulb-168948/)
94dgrif 01-12-2013 05:46 PM
I have been having a huge amount of trouble identifying a halogen blown halogen light bulb I need to replace in our oven. I have looked at the bulb, the fixture, the lens, the heat shield, the manual, called the manufacturer, looked at the oven parts list, contacted a third-party parts website and ultimately I believe I know the specs for the bulb, but I feel I need to know the risks of getting it wrong.
I believe the bulb is a 120V, 20W, G5.3 Bi-pin - something similar to this. Note that the image is of a G8 not a G5.3!
I'm not asking for help finding the bulb for sale (although if I can confirm the specs then that would information would be really useful!). Instead I'd like to know:
- What would happen if I put a 120V bulb in a 12V fixture?
- What would happen if I put a 12V bulb in a 120V fixture?
- Can a bulb be rated for external temperature as well as fixture type, voltage and wattage?
rjniles 01-13-2013 05:54 AM
120 volt lamp in 12 volt fixture will not light
12 volt lamp in 120 volt fixture will blow out in a second.
Temperature rating should not be an issue.
94dgrif 01-13-2013 12:38 PM
Perfect answer! Thank you very much - I'm going to hunt down a 120V bulb and test it out.
