Replacing Kitchen Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 04:24 PM   #1
I need some electrical help: I am replacing the lights in my kitchen...I removed the lights 6 weeks ago to rid the ceiling of popcorn and I had just bought the house. On Sunday when I went to put up the new light fixture, as shown in the pics, I found that this one box has lots of wires...2 sets of 3 wires wrapped together, including both whites and blacks on each set. When I took the old fixture down, I didnt pay attention which side the black wire and the white wire from the fixture was attached to on the box.
I was told all these wires are because they are running wires to a second circuit (right terminology?) to be controlled by the same switch.
I have 3 lights in the kitchen - This one pictured, a second one over the sink - which has it's own switch for and I could see some wires wrapped together stuffed up in the box, and then the 3 wires hanging down to attach to (the ground, white and black). The third light is over the dining area and has only 3 wires - black, white, and ground but is controlled by the same switch panel as the main light (with all the wires).
I couldnt get any lights to work...Guess my main question right now is - does the main light box have to be properly working and connected before the other 2 lights will work?
Replacing Kitchen Lights-kitchen-light-box-.jpg   Replacing Kitchen Lights-kitchen-light-box-b.jpg
amber07 is offline   Reply With Quote
Old 12-11-2012, 05:09 PM   #2
Rewards Points: 2,516
a white conductor wire nutted to blacks is most likely a switch loop. The white conductor should actually be marked black at its ends. see diagrams below for further. Im sure they do not match your exact situation but may help:
I do not show any ground wires for ease of drawing
Replacing Kitchen Lights-switch-2520loop2.jpg   Replacing Kitchen Lights-switch-20loop.jpg
hammerlane is offline   Reply With Quote
Old 12-11-2012, 05:18 PM   #3
this may be your setup:
Old 12-11-2012, 06:09 PM   #4
Thank you!!
This is ALL very new to me, so when I go to the house next, I will have to test it out...
Old 12-12-2012, 05:31 AM   #5
Really?? Where have you been for the last 100 years? ABout how long electricity has been in homes
installing kitchen recessed lights UFoPilot Electrical 8 03-27-2012 11:10 PM
LED kitchen lights pw5599 Electrical 8 11-13-2011 11:32 AM
Replacing parts of a kitchen LilDave Kitchen & Bath Remodeling 7 04-09-2010 06:42 PM
Kitchen Lights - Weird Problem Chris Newell Electrical 6 11-08-2008 11:06 AM
Replacing Dimmer for kitchen lights tmcguirk Electrical 2 04-16-2008 08:38 PM
