-   -   Replacing HVAC Thermostats (http://www.diychatroom.com/f18/replacing-hvac-thermostats-13557/)
handy man88 11-19-2007 07:54 AM
I bought 2 thermostats and will be replacing the old one which does not have a screen. I saw on the back of the package where they recommend shutting the power off before replacing. There are 4 leads coming to the thermostat. Which ones need to be measured to make sure it's safe?
J. V. 11-19-2007 11:41 AM
Turn off the main breaker for the AC. This is low voltage at the thermostat. But it is possible to fry the circuitry if you were to short out your new electronic T stats while connecting the wires.
Don't take a chance. kill power to the ac.
handy man88 11-19-2007 11:48 AM
Thanks for the advice. Very much appreciated.
frenchelectrican 11-19-2007 11:58 AM
also let me add one or two comments.,,
make sure the furance/ air handler power is off as well.
when you replace old thermostat with new thermost just make a note how it connected follow the colour codes with the relalted lettering sometime it will have slightly diffrent lettering.
if any chance the old thermost did not have any marking the sure fire tip is check the furance/ air handler contol panel and see how it termated there so it should pretty much line up the same.
the reason why i mention that because not always be the case with colour code sometime one of the wire is broken or something else screw up and have to use other spare wire.
Merci , Marc
handy man88 11-19-2007 01:43 PM
Merci , Marc
You are very right. I have dealt with some contractors recently who are probably the worse ever. Imagine a contractor doing something wrong, something that doesn't cost much, and then when asked, he says he's not responsible and does not offer a warranty for his work that took place 2 weeks ago.
