Replacing A Hard-wired Shielded Cable At A Light Switch With A Three-prongg Plug. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 02:34 PM   #1
replacing a hard-wired shielded cable at a light switch with a three-prongg plug.
I need to replace a hard-wired shielded cable at a light switch with a three-prong plug on my replacement garberator. I figure I can simplly clip off the plug and hard-wire the ends as the former garberator was. Right?
Jim Ross is offline   Reply With Quote
Old 02-16-2012, 04:02 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm not understanding the question. I assume your asking if you can cut the plug of your new garburators power cord and wire it to the switch ??
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-16-2012, 05:11 PM   #3
joed's Avatar
Rewards Points: 13,748
If you mean the old unit was direct wired with what is common called BX cable, then simply put a box on the end of the cable with a receptacle in it.
Does your cable look like one of these?
Old 02-16-2012, 05:26 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Joe
Is he talking about a garbage disposal ?
Stubbie
Old 02-16-2012, 07:51 PM   #5
joed's Avatar
I believe he is talking about a garbage disposal. It must be a Canadian thing to call it that.
The Following User Says Thank You to joed For This Useful Post:
mpoulton (02-16-2012)
Old 02-17-2012, 11:12 AM   #6
http://www.google.com/search?client=...w=1211&bih=683
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 05:24 PM
replacing a light switch for mobile home kelley.doyle Electrical 1 11-14-2011 06:30 PM
replacing a dimmer switch with regular switch demus72 Electrical 2 11-10-2011 01:54 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
