Replacing Hall Light Fixtures With Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2008, 10:07 PM   #1
Replacing hall light fixtures with recessed lights
I'm doing a straight one for one replacement of some flush mount ceiling fixtures with 5 inch recessed lights (IC rated). My question is with the wiring. The flush mounted fixture just had the black and white wires connected (the bare wire from the switch was coiled up and capped by the builder). The recessed lighting fixture has the black and white connections and separate green and bare wire connectors (the green/ground wire is connected to the box of the fixture). Do I just use the bare wire fixture connector to connect to the bare wire from the switch (and leave the green/ground fixture wire alone/disconnected) or should I combine the green and the bare wire at the fixture and connect them to the bare wire from the switch? So I would have:
Switch--Fixture
Blk------Blk
White---White
Bare----Green
Bare----Bare
Thanks in advance for your help.
POMEXCAN is offline   Reply With Quote
Old 04-16-2008, 10:31 PM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The green is for grounding the box. The bare is for grounding the fixture. Connect them both to the bare from the switch box with one wire nut. Look in the switch box and make sure the ground is connected to the bare wire which feeds the switch or if it is curled up in there too.
The black - black and white - white is correct.
jrclen is offline   Reply With Quote
Old 04-16-2008, 10:40 PM   #3
Registered User
Termite's Avatar
Your bare wire and green wire can and should be twisted and wire nutted together. Be sure to pigtail a ground to the green screw on the switch if it is in a plastic box. If it is in a plastic box and doesn't have a green screw, you have the wrong switch.
Old 04-16-2008, 10:40 PM   #4
Sounds good - I'll check the switch as well to make sure the bare wire is connected there too. Thanks for the quick response!
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
