Replacing GU10 Bulbs? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 03:56 PM   #1
Rewards Points: 562
I want to replace (7) 120 volt, 50-watt GU10 bulbs in my home theatre with bulbs that have the same brightness, but are a lot more energy efficient and cooler to operate. I've looked into LEDs, but most of them are very dim. Perhaps I'm not looking in the right place.
Any recommendations?
kcrossley2 is offline   Reply With Quote
Old 01-27-2011, 04:39 PM   #2
You are looking for a 6w LED , the only ones i've seen at the big box stores are the 3w. they are still new and expensive, especially if you want dimmable.
dhubz is offline   Reply With Quote
Old 01-27-2011, 04:43 PM   #3
Rewards Points: 562
So where is the best place to purchase a 6W LED. I do not need dimmable. Thanks for your help.
Old 01-27-2011, 05:03 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
have you tried those in the picture here?
http://www.google.com/search?rlz=1C1...8&q=6+watt+LED
Old 01-27-2011, 05:30 PM   #5
Rewards Points: 562
The problem with the LEDs is they are only 55 lumens, whereas a 50-watt halogen bulb is around 480 lumens.
Old 01-27-2011, 05:39 PM   #6
nap
You talking to me?
nap's Avatar
330 lumens? http://www.google.com/products/catal...d=0CDUQ8wIwAg#
330 lumens. 55 lumens/watt efficacy.
that's the brightest I can find. Sounds like you are stuck with that you have.
Old 01-27-2011, 05:41 PM   #7
Rewards Points: 562
Not bad, but at $50 per bulb that would cost me $350. Wow!
Old 01-27-2011, 07:51 PM   #8
Electrical Supplier
Rewards Points: 150
you would actually want an LED unit closer to 10 watts......
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-27-2011, 11:49 PM   #9
Rewards Points: 562
Know where I can get one?
Old 01-28-2011, 12:56 AM   #10
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Try Cree, I love these things.
May be pricey though.
Andy.
O.K. got it fixed.
AndyGump is offline   Reply With Quote
Old 01-28-2011, 01:36 AM   #11
" Euro " electrician
frenchelectrican's Avatar
Andy.
Can you fix the link a little? I am comming up a error.
Merci.
Marc
Old 01-28-2011, 07:34 AM   #12
Rewards Points: 562
Merci.
Marc
I think this is it: http://creelighting.com/
But I don't see any GU10 bulbs.
Old 01-28-2011, 06:28 PM   #13
Most of the bulbs in my house are GU10. When it comes to bulbs, CFL is going to get you the best bang for the buck.
suprvee is offline   Reply With Quote
Old 01-29-2011, 12:56 AM   #14
Rewards Points: 562
A CFL would be fine. The problem is the only GU10 CFLs I've found are 35 watt equivalents, plus the CFL fixture appears to be too high for the housings I have, which are being used as wall sconces.
http://www.lowes.com/pd_243789-47842...ght%26page%3D5
Old 01-29-2011, 01:06 AM   #15
Rewards Points: 562
Actually, this may work for the four recessed GU10's I have, but the sconces are still a problem, especially because of the CFL bulb depth and the fact that a small metal ring is used to secure the bulb.
http://www.amazon.com/Bulbrite-CF15R...284655&sr=1-32
OOPS! Won't work. This has a GU24 base.
5 Watt A15 light bulbs for bath Metallo Appliances 2 01-22-2011 08:54 PM
Replacing incandescent bulbs with CFL bulbs NightOwlNYC Electrical 5 08-18-2010 11:45 PM
flourescent bulbs keep popping. darsunt Electrical 12 02-06-2010 10:10 AM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 02:34 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
