Replacing GFI - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 04:50 PM   #1
Replacing GFI
I'm replacing a GFI outlet, as the original's reset button won't release. After I hook up all wires, the outlets work but the load doesn't travel to the next outlet.
Any ideas?
Jim
jimerick is offline   Reply With Quote
Old 06-19-2011, 05:05 PM   #2
" Euro " electrician
frenchelectrican's Avatar
All the GFCI are very specfic with line and load connections so you have to see which set is line and load that for both incomming and outgoing wires.
Make sure you have excat pairs when you look at the cables and it can not be crisscrossed otherwise the GFCI will lock out or not functing at all.
Merci,
Marc
Replacing water line for refrigerator seannymurrs Plumbing 13 04-09-2011 07:30 AM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 08:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 09:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
