Replacing A Fused Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-10-2008, 06:05 PM   #16
Wow, I thank you for the infor ind the friendly? banter on this subject. I will check on cost for upgrading wire. The old panel is a Buldog and it states. 125v 2 wire, grounded neutral. I traced it back to the main panel and the 3rd stranded wire ( this is se cable) is attatched to the neutral bar.
One question is, why did not the electrician installing the new panel or the inspector, make mention that the old sub panel was, did not have a ground wire returning to the main panel?
Is it a case of, we'll let it go this time? and in the event so, why not allow a new subpanel be connected in the same dashion? I do see the value of a separate ground from the sub back to the main. Am I to understand that without a grounded subpanel, the breakers may not trip?
Thanks, keep up the banter.
ltlbud36@comcast.net is offline   Reply With Quote
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 10:43 AM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 03:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
