Old 09-27-2012, 12:54 PM   #1
Question
Replacing freezer door on Frigidaire
Hello all! I have a frigidaire FRS23LH5DQ3 that is less than 8 years old. I have rust on the door below the ice & water dispenser. I finally found the replacement door. The door did not come with the wiring harness or water tube for the ice & water dispenser. What will be the easiest way to remove those from my old door and install in my new door?
Thanks for the help.
samkat is offline   Reply With Quote
Frigidaire 12 c/f fridge not working Freezer works IDIMyself Appliances 2 09-12-2012 06:08 PM
Frigidaire Freezer Problem LensGrinder Appliances 2 08-07-2012 10:42 PM
Frigidaire side by side freezer works refrigerator doesn't! Towerdog2 Appliances 11 07-22-2012 10:26 PM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 10:16 AM
old Kenmore chest freezer - worth replacing starter relay? Pickngrin Appliances 0 06-27-2010 10:07 AM
