Replacing Faulty GFI In Kitchen. Wires Too Short. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2008, 04:11 PM   #1
Question
Replacing faulty GFI in kitchen. Wires too short.
The GFI in my kitchen went out and I am trying to replace it.
I'm new to home electrical work, but have worked with bread boards and have done some lightweight electronics repair.
When I pull my faulty GFI out of the wall, there's only enough wire to get it out about an inch, so it's a very tight fit.
I am having a problem getting it back into the wall. I have no idea how people would be able to do this as the wires each come out only an inch (to the tip) from the wall, it seems impossible to manage. And since the wires are thick and hard to bend it's very difficult to curve them around the screws on the new GFI.
I'd really appreciate any advice that could be given. Currently i have twist caps installed on all the wires to prevent destruction.
ShawnMcCool is offline   Reply With Quote
Old 06-02-2008, 04:24 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Take about a 6" piece of black, white, green or bare and wirenut them to the existing wires (color to color) and this will extend them
wirenut1110 is offline   Reply With Quote
Old 06-02-2008, 04:32 PM   #3
The wires coming from the wall are fairly thick. Do I need to match them to equal thickness wires? Are there standard sizes for these wires and how do I know which wire nuts are the right size for my job, so that they don't pop off and burn my house down?
I appreciate the reply. This is my first foray into repair of this sort.
Old 06-02-2008, 04:48 PM   #4
Rewards Points: 510
Use 12 gauge wire and red (#76) wirenut, twist the ends together not the whole wire and put the wirenuts on tight.
Old 06-02-2008, 04:48 PM   #5
Thank you
Old 06-02-2008, 08:21 PM   #6
Pass and Seymore brand GFCI's terminate in the back/sides
I can see the OP struggling to stuff the added wires in the box
Sorry, I'm laughing with you.
Wait....you're not laughing, you are probably cussing.
220/221 is offline   Reply With Quote
Old 06-03-2008, 09:05 AM   #7
When is fishing season?
CowboyAndy's Avatar
Shawn, Most GFI's are backwired, where there are holes in the back of the receptacle the wire would stick straight into. Then, you tighten the screws on the side to clamp them in place.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 06-03-2008, 06:55 PM   #8
Advice worth 2 cents!
Rewards Points: 150
Hey Shawn,
I love to see folks doing their own work but, you might wanna have a "tradesman" neighbor or a friend who's an electrician check your work out. The situation that you have is a bit tricky and you need to make sure your making solid connections...if your confident about that it should be O.K.
- pete
---pete
HandyPete is offline   Reply With Quote
Old 06-04-2008, 03:31 PM   #9
Also need to make sure you're connecting the wires to the load side of the receptacle, to make sure downstream receptacles are protected.
NateHanson is offline   Reply With Quote
Old 06-04-2008, 05:15 PM   #10
Registered User
Termite's Avatar
Wire nuts can get tough in tight spaces, especially for DIY-ers.
Another option is to use short lengths of the wire (of the same size), attach them to the terminals of the receptacle, and use these to connect instead of wire nuts. They're called "Wago Wall-nuts", and they work great. You can get them at HD or Lowes, and they're also sold under the Ideal brand name. They cost more than wire nuts, but you can buy assortment packs for a couple bucks. Great for short wires in tight boxes.
Old 06-04-2008, 07:22 PM   #11
CowboyAndy's Avatar
The only problem is that a standard 1 gang box is tight enough with a GFI receptacle, let alone with wirenuts. I am willing to bet the previous GFI was backwired, so the new one should go in just as easy as the old came out.
MY HOUSE OWNS ME!
Old 06-09-2008, 02:26 PM   #12
Rewards Points: 80
You mean line side right?
Old 06-09-2008, 09:41 PM   #13
I think he meant, the outgoing wires since he was referring to the downstream receps.
Tags
gfi , kitchen , replacement , short , wires
Replacing Kitchen Cabinet Door Hinges Eric_ht Carpentry 4 04-18-2008 08:42 AM
Replacing Dimmer for kitchen lights tmcguirk Electrical 2 04-16-2008 09:38 PM
Replacing a kitchen sink-problems doubledave27 General DIY Discussions 2 05-30-2006 04:36 PM
Replacing kitchen sink knob? Pikaia Plumbing 4 06-09-2005 10:43 PM
Short Wires sensen Electrical 3 04-01-2005 01:36 PM
