Replacing Existing Light With Can Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 07:18 PM   #1
Rewards Points: 85
replacing existing light with can light?
In my house, I have a florescent light in the addition part of my kitchen. My plan is to replace it with a 4" can light and add two more to the left and right of the existing light. My problem is I don't know how to branch the wires off to the left and right b/c there is no access from above.
mferguson0414 is offline   Reply With Quote
Old 01-22-2009, 07:56 PM   #2
Remodeling Contractor
Turn of the electric. Remove the junction box. Place these wires into the junction box for this center light. Run another 14/2 from this one to the left one. For the left one run 14/2 to the right one. Connect all the ground wires (bare or green) ones together. All the whites go together and all the blacks go together.
Old 01-22-2009, 09:51 PM   #3
Electrician
ctsmiths's Avatar
Rewards Points: 150
Do you mean there are joists in the way?
ctsmiths is offline   Reply With Quote
Old 01-23-2009, 08:24 AM   #4
Rewards Points: 85
yes ctsmiths, there are joist, sorry I should have said something about them being in the way
Old 01-23-2009, 08:33 AM   #5
use a drill with a long extension and drill a hole into the next joists. At Home Depot or an electrical supply house the sell long drill bits for this purpose that have a small hole on the end to attach a fish wire so you can then reverse the drill and slowly pull the wire into the new hole from the new recessed can hole into the center junction box.
Old 01-23-2009, 08:45 AM   #6
Rewards Points: 1,448
Check to see if there is a gap between the ceiling material (drywall, etc.) and the joists and see if you can insert a stiff wire (or electrician's fish tape) along the top of the ceiling material over to your other light positions.
This does not always work since the furring strips running perpendicular to the joists and to which the ceiling material is attached (yielding the gap) may also be in the way.
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 11:16 AM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 08:16 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
