Replacing An Existing 1-way Decora Light Switch With A Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 12:28 PM   #1
Rewards Points: 16
replacing an existing 1-way decora light switch with a dimmer switch
Looking for some help on how to wire a dimmer switch. It's single-pole one way and is housed in a 2-gang box on the same circuit with another single-pole one way switch.
The dimmer has 3 wires - 2 black wires and one green (the ground).
The existing switch that I want to replace has 2 black wires connected to it but no ground. I can see that all the white wires for both switches are marretted together in the back of the box.
So if I remove the existing switch I will have 2 black wires that I need to connect and marrett to the 2 black wires on the dimmer. Does it matter which one gets connected? I can see no identifying info on the sheathing of any of the 4 wires in question.
Secondly, what can I do with the ground wire? Do I have to attach it to the box or can I just clip it off?
maljeff is offline   Reply With Quote
Old 01-11-2012, 12:32 PM   #2
Mad Scientist
The black wires from the dimmer go to the black wires that were on the existing switch. It doesn't matter which wire connects to which. Are there any ground wires in the box? Is the box metal or plastic?
McSteve is offline   Reply With Quote
Old 01-11-2012, 12:42 PM   #3
Rewards Points: 16
McSteve:
Thanks for the reply. The box is metal and there are ground wires connected to the box already.
Old 01-11-2012, 12:49 PM   #4
Mad Scientist
Alrighty, the ground wire for the dimmer should be connected to the other ground wires in the box.
Theoretically, all the incoming ground wires, a ground wire from each switch, and a ground wire attached to the box should all be connected together. If this isn't the case, you might want to try to correct it while you're in there.
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
3 Way Dimmer Light Switch Problem psubaron Electrical 4 07-13-2011 09:08 PM
replacing old receptacles with new decora on a 3 way light switch furniture man Electrical 3 03-06-2011 09:23 AM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
