Replacing Duplex Receptacle With Nighlight - Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 12:11 PM   #1
Replacing duplex receptacle with nighlight - wiring question
Hi all,
I am replacing two duplex receptacles with units that feature a single receptacle and a nightlight. The wiring is different on the new ones and I want to make sure I'm proceeding the right way because I'm scared of death and fire (and monsters).
The current installation has 3 pairs of black/white wires and a bare ground. Two pairs are connected to screws on the sides and the third pair is going directly into the back. Each receptacle is downstream of a GFCI receptacle, but it's not GFCI itself.
The new nightlight receptacle only has connections for one pair (silver screw on one side and black screw on the other) and the ground.
My plan is to wire nut all three black wires with a jumper to the black screw on the receptacle and do the same thing with the white wires to the silver screw and connect the ground to the ground screw. Is this correct? In this setup it doesn't matter which is the lead pair and which are the loads, right?
Thanks for your help. It is much appreciated.
Charlie
Rabu is offline   Reply With Quote
Old 05-01-2010, 12:29 PM   #2
Master Electrician
Rewards Points: 3,746
Your plan is correct.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Rabu (05-01-2010)
Old 05-01-2010, 12:47 PM   #3
Thanks a bunch!
Old 05-01-2010, 12:57 PM   #4
Just call me Andrew
Rewards Points: 1,020
THe only thing to take into consideration is box fill. Is the outlet the only thing in the box? If so, you have 2 conductors coming in and 4 going out. That's a total of 6 . All the grounds count as 1, that makes 7. Each device (outlet/switch) counts as 2 conductors. Now we're up to 9. Clamps count as 1 (metal box). Up to 10 now.
For 12 gauge wiring (worst case scenario for box fill) each conductor needs 2.25 cubic inches.
12 x 2.25 = 27 cubic inches - bigger than most single gang boxes.
Best case scenario for a single gang box:
Plastic box (probably no clamps) and 14 gauge wire: 22 cubic inches.
Hopefully I did that all correctly.
Andrew
secutanudu is offline   Reply With Quote
Old 05-02-2010, 04:45 PM   #5
Originally Posted by secutanudu View Post
THe only thing to take into consideration is box fill....
You lost me a bit there, but I'm assuming you're talking about being able to physically get that much stuff in the box. I got it all in there and everything is working, so I think I'm good to go.
If I misunderstood what you meant and need to redo it differently, any clarification would be appreciated. I'm an electrical newbie, if you didn't guess that already.
Thanks,
Charlie
Old 05-02-2010, 04:54 PM   #6
Just call me Andrew
THere is a legal limit to box fill, not just how many you can stuff in
I have found that usually, if you can fit it in without too much trouble, it's probably legal. But you should do the calculation anyway to be safe. Read this for more info:
http://www.selfhelpandmore.com/home-...tions-2002.php
Andrew
Old 05-02-2010, 08:51 PM   #7
Electrical Contractor
kbsparky's Avatar
Simply replacing a wiring device will not change the box fill calculations/requirements.
If it was in compliance before, it will be in compliance after.
If it was overfilled before, then it will still be overfilled.
-KB
Is it acceptable to use push connectors AND screws on a duplex receptacle? Bob K. Electrical 5 03-07-2010 08:14 PM
Basement wiring question kupalino Electrical 8 11-14-2009 10:25 AM
Closet question: options and wiring diagram? schnitz411 Electrical 6 10-24-2009 12:45 PM
Replacing a standard receptacle with a GFCI dsb Electrical 5 05-31-2009 10:08 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
