Replacing Duplex On House W/Aluminum Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 07:17 PM   #1
Replacing Duplex On House w/Aluminum Wiring
Any feedback would be appreciated on replacing inside duplex wall plug with aluminum wiring, house built in 1969, current wiring has short leads and I purchased 12-10 butt splices to use on short leads, using liquid no-lox and obviously romex 14/2 to other end of butt splice.
Any danger other than aluminum wiring?
Thanks Mike
Mike Moody is offline   Reply With Quote
Old 11-23-2011, 07:31 PM   #2
Electrician
Rewards Points: 780
I wouldn't use butt splices, I can't say off the top of my head if there against code or not but I have never seen it done.
You have two options, buy aluminun rated plugs, but those are expensive.
Second option is to get aluminum to copper marrets. Put some no-ox on the joint as well and you will be good to go.
darren is offline   Reply With Quote
Old 11-23-2011, 07:57 PM   #3
All about aluminum wiring repair from the U.S. Consumer Product Safety Commission...
http://www.cpsc.gov/cpscpub/pubs/516.pdf
Billy_Bob is offline   Reply With Quote
Old 11-24-2011, 08:30 AM   #4
Rewards Points: 1,452
deleted.
Old 11-24-2011, 12:45 PM   #5
Rewards Points: 82
You cannot use anything that is not listed for AL to CU. The butt splices are not listed for this application. Use one these (pictured below) or use a AL/CU rated receptacle.
Old 11-24-2011, 12:54 PM   #6
Rewards Points: 582
agree with darren don't use butt splices...and use only al/cu rated receptacle even if they do cost more safty is more important than cost ....
Old 11-24-2011, 12:57 PM   #7
Also aluminum wire has a problem called "cold creep" (google aluminum wire cold creep). This means the wire will expand and contract with an electric load, then no electric load (heat, no heat)...
So aluminum wire is a slippery slimy little rascal which needs to be held FIRMLY in place! It must be "restrained" or it will escape!
Thus *very* important to read the full installation instructions. If these say to tighten the screws to a certain "inch pound" tightness using a torque wrench, then get the proper tools to do that. 12 inch pounds equals 1 foot pound. And if the instructions say to use a certain "anti-oxidation" compound and to first wire brush the wire or whatever, then VERY IMPORTANT to do that!
I think the copalum crimp method done by a certified electrician is the best.
The Following User Says Thank You to Billy_Bob For This Useful Post:
ben's plumbing (11-24-2011)
Hot tub wiring from main house robmet1015 Electrical 8 08-02-2011 09:22 AM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 10:03 PM
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 08:51 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
