Replacing A Doorbell Button - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 06:52 PM   #1
Replacing a doorbell button
I need to replace the doorbell button on the outside wall. What electrical considerations should I be aware of? None of the circuit breakers are labeled for the doorbell.
GeoInMo is offline   Reply With Quote
Old 09-13-2011, 06:57 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The door bell is low-voltage and doesn't qualify for a circuit breaker. Just change the door bell button and don't worry about it. I doubt you'll even get a tingle. The bigger problem is if you touch the wrong wire at the wrong time it will cause your ears to grow.
Old 09-13-2011, 06:59 PM   #3
Rewards Points: 6,652
If none of the breakers are labeled for the doorbell, find out where the transformer is. Is it on the side of the breaker panel, or somewhere in the ceiling? If on the breaker panel, that means taking off the cover and looking to see where the wires attach on a breaker. You may also be in for a surprise if you have not opened the panel before, if the previous home owner did some weird stuff with wiring.
Old 09-13-2011, 07:53 PM   #4
Code05's Avatar
Rewards Points: 1,104
Code05 is offline   Reply With Quote
Old 09-13-2011, 07:57 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I knew that would set-off somebody around here. Just don't lick the damned thing, it'll be fine. B-z-z-z-z-z-z-z
Old 09-13-2011, 08:31 PM   #6
Or touch the wires together.
Old 09-13-2011, 09:39 PM   #7
concretemasonry's Avatar
Rewards Points: 2,640
I just replaced an illuminated button that was destroyed/broken by someone. It took about 3 minutes to remove the old lighted button with a new one. The reason it took so long was that the spacing of the old and new plate was 1/4" different, so a new hole had to be drilled. No need to flip a breaker because it was low voltage.
Everything worked before the damage, so I just did a replacement and avoided any modifications until I hooked up the new one and tested the operation before tightening the face plate screws. - It is only low voltage.
Dick
concretemasonry is offline   Reply With Quote
Old 09-13-2011, 11:24 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 2,112
Ya know....after dealing with the wiring in my house with the original wiring for the door bell......I'm now a real big fan of the wireless door bells.....
You can put the button and bell where ever you want...
No wires to deal with
After 5 years, still on the original batteries....but then again, I doubt the door bell gets used more than 5 times a year.....
Old 09-14-2011, 05:10 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
If you touch the wires together all you do is ring the chime.
Coastal South Carolina
help replacing a doorbell button wannabdiy Electrical 1 01-30-2011 05:29 PM
Question about 2 family doorbell button rns6799 Electrical 1 09-26-2010 07:47 AM
hot doorbell button rustic Electrical 10 01-27-2009 12:16 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 11:36 AM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
