Replacing Disposal...wiring Regs - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 04:14 PM   #1
Replacing disposal...wiring regs
Current install has a electrical box with a switch surface mounted under the sink. Then NM wire from the switch box to the disposal. That's how it was when I bought the house, and I've replace the disposal once, using the same setup. It lived a good life but is leaking and needs replaced.
New disposal has a plug. So I have the option to install an outlet or just removing the plug and using the existing NM wire.
Here's the issue. I'm reading a Black & Decker book and it says NM wire is not permitted in an open area where it can be damaged. Ok, but it makes me wonder.....if NM wire is a no-no, why is a cord with a plug on the end allowed? Does a cord offer more protection than the sheath on NM? I wouldn't think so.
twinrider1 is offline   Reply With Quote
Old 04-28-2011, 04:55 PM   #2
Rewards Points: 330
basicaly,nm(romex) is part of permanut wiring so it needs to be protected.disposal is a cord and plug connected appliance just like washers,friges ect.it is a whole different matter.you can put the romex in wiremold if you want as it should be to box.
oleguy74 is offline   Reply With Quote
Old 04-28-2011, 05:19 PM   #3
It's only exposed from the switch box to the disposal itself.
Thinking a new 4x4 electrical box, with both a switch and an outlet is the way to go. Though it sure is tempting to just wire it back like it was for the past 10+ years.
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 07:51 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 03:00 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Replacing under-baseboard wiring in basement brn Electrical 3 02-01-2009 04:15 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
