Replacing Direct Wired CO2 Detector Into Junction Box. Not Sure Which Wire Is Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 02:11 PM   #1
Rewards Points: 54
replacing direct wired CO2 detector into junction box. Not sure which wire is hot
I'm replacing a direct wire CO2 detector, but I'm not sure which of the two wires in the junction box is hot and which is neutral. Both wires are white, and I lacked the foresight to mark which is which before disconnecting the old unit.
Here is a picture of the wires running into the outlet, and out of the outlet to the junction box. From this picture, can anyone tell me which of the two white wires running into the junction box is hot and which is neutral?
bodiroti is offline   Reply With Quote
Old 11-08-2012, 02:17 PM   #2
Licensed electrician
Rewards Points: 1,236
The hot is connected to the brass side of the receptacle.
The installer should not have used a white as a hot in the raceway. I would wrap a black tape around both ends of the hot to avoid this confusion. Even bterr would be to replace it with a black or red conductor.
Old 11-08-2012, 02:41 PM   #3
Rewards Points: 54
thanks, so just to be clear before i blow something up, the brass side is the side with the black hot wire, and the hot wire going to through the raceway is the white wire from the same side as the black wire?
Old 11-08-2012, 03:22 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Correct!
jbfan is online now   Reply With Quote
Old 11-08-2012, 04:26 PM   #5
Rewards Points: 54
thanks for your help! i managed to do it without blowing myself or anything else up
Tags
co2 detector , direct wire , junction box
replacing ceiling fixture - hole in ceiling with wire hanging out sunshine1221 Electrical 4 08-20-2012 10:53 AM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-05-2011 12:17 AM
Replacing a two wire heat thermostat to a four wire cibao67 Electrical 2 03-01-2010 09:42 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
Converting plug-in undercabinet light to direct wire ccole10 Electrical 4 07-21-2005 11:58 AM
