Replacing Dimmer Switch With Regular Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 08:52 PM   #1
Replacing dimmer switch with regular switch?
I went to go replace a dimmer switch with a regular switch turned on the power but the lights did not come back on. There are two lights that the old dimmer switch fed and the switch I put in was a 1pole could this be the problem. Or are there only certain lights that will only work with dimmer switches and not with 1 pole switches.
LOUSY CARPENTER is offline   Reply With Quote
Old 07-31-2009, 10:36 PM   #2
Remove the switch and connect/wirenut the hot and light legs (the two wires you connected to the switch) together to see if light works...
You might have a bad switch, and that can happen to anyone.
I would do that for starters if you don't have a tester to check for continuity between the two wires. Have you checked the breaker to make sure it is on or not tripped? ...
I am assuming you have no testers.
Timster is offline   Reply With Quote
Old 11-05-2010, 08:21 PM   #3
Rewards Points: 5,336
If you replaced a 3 way switch with a regular dimmer, there would be issues.
Is that what you did?
Ron
Weird problem replacing dimmer switch cdale600 Electrical 9 01-20-2009 09:31 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Replacing Dimmer Switch dallas520 Electrical 3 05-15-2005 12:49 PM
