Replacing Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2005, 03:07 PM   #1
I Would Like To Replace Dimmer Switch Currently Installed. This Switch Has 2 Black Wires Only. The New Switch Has 2 Black And One Green. What Do I Do With The Green Wire? The Box Is Plastic.
Dallas 520
dallas520 is offline   Reply With Quote
Old 05-14-2005, 09:21 PM   #2
Contractor
The green wire is a ground. If you have metallic boxes, you can ground to them or a green wire in the box. If your home is older, just ignore the green wire but I didn't say that. Strictly speaking, all electrical modifications have to be brought up to current code. Strictly speaking, this can cost you a fortune.
Teetorbilt is offline   Reply With Quote
Old 05-15-2005, 09:48 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
HUH??? To install a dimmer.
If the box is plastic there will surely be a ground wire. Ground wires came before plastic boxes.
Connect the green to the bare ground(s) in the box.
Old 05-15-2005, 12:49 PM   #4
Contractor
That's what my electrician tells me.
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Dimmer Switch Problems? dmtm21 Electrical 2 08-07-2007 02:18 AM
replacing light switch in bathroom cooper Electrical 3 02-22-2007 06:05 AM
Dimmer switch Remodeling Electrical 3 06-23-2006 04:08 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
