Replacing Cord On A 1.5 Hp Above Ground Pool Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 06:31 PM   #1
Replacing cord on a 1.5 hp above ground pool pump
The ground prong on the cord to my 110 V, 12 AMP, 1.5 HP pump for my above ground pool remained in the receptacle when I unplugged it. I replaced it with a new 15 AMP cord from ahome improvement store. Is there any problem with the fact that it's 15 AMPs and the pump is 12 AMPs? It is working, but I think it sounds a little different than it did before I replaced the cord.
Thanks for your advice!
LeeAmes is offline   Reply With Quote
Old 04-19-2009, 06:49 PM   #2
joed's Avatar
Rewards Points: 13,766
You will be fine if you replaced the plug with one of the same configuation. Are the prongs on the new plug the same as the old one?
Old 04-19-2009, 07:09 PM   #3
Yes, they are the same - thanks for your reply!
Old 04-19-2009, 07:20 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
If the cord and plug are not warm to the touch when the motor is running you should be OK
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-19-2009, 07:29 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Remember, the cord MUST be #12ga to be code legal. I am sure there are other code issues as well.
How old is this installation?
Old 04-19-2009, 07:40 PM   #6
Thanks for the replies!
The cord and plug are not warm to the touch and it is #14ga cord...
Old 04-19-2009, 07:42 PM   #7
And the installation is less than 3 years old.
Old 04-19-2009, 08:21 PM   #8
How long is the cord?
Old 04-19-2009, 08:25 PM   #9
It's 10 ft
Old 04-19-2009, 08:30 PM   #10
Res Ipsa Loquitur
Do you need to have it 10 ft long? 1.5 hp is a powerful motor to be on a cord- especially a long one. I would want to have the shortest cord that could reach the outlet without any problem. Also, as mentioned before the cord should be at least 12gauge.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 04-19-2009, 08:35 PM   #11
that's a good point. It is 14 gauge -- sorry for the stupid question, but is that enough? I don't know if 14 gauge is more or less than 12 gauge in terms of electrical capacity.
I can make the cord shorter -- I had to put the little connectors on to attach it to the pump. Should I take it off, cut it down, put the connectors on and re-attach? The pump is only a few feet from the receptacle so it doesn't need to be 10 ft long.
Old 04-19-2009, 08:45 PM   #12
12A through 10' of #14 = a 0.5% voltage drop, but I don't know how much more voltage you lose with plug/socket contact resistance at each end.
Old 04-19-2009, 09:55 PM   #13
Why did you replace the cord instead of just replacing the plug?
And why would it have to be a 12 ga. wired cord for 12 amps? 14 ga, cord is rated for 15 amps.
hayewe farm is offline   Reply With Quote
Old 04-19-2009, 10:08 PM   #14
How long was the old cord?
I seem to remember a Max length - 6' on cords for pool pumps??
Do you still have the old cord - see if you can read a wire gauge off of it
12g = 20 amps = 2400 watts
14g = 15 amps = 1800 watts = lighter duty
Your pump pulls 12a (Max?) = less then either of these
BUT, sometimes they want a heavier duty cord due to the length of time a pool pump is usually on
My pool pump was pulling 18.6a Max by the rating on the pump
So I hard wired it at 240v
Is this pump on a timer?
That is required here
Old 04-19-2009, 10:12 PM   #15
Except that the current installation could violate code & Mfg recommendations
in ground pool chad2423 Building & Construction 4 09-28-2009 09:41 AM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 07:30 PM
pool pump BillyD Plumbing 4 05-12-2008 10:07 PM
need instructions on replacing a Whirlpool refrigerator power cord please. ChrisC30 Electrical 2 03-10-2008 09:59 PM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
