-   -   Replacing cord on a 1.5 hp above ground pool pump (http://www.diychatroom.com/f18/replacing-cord-1-5-hp-above-ground-pool-pump-42818/)
LeeAmes 04-19-2009 06:31 PM
The ground prong on the cord to my 110 V, 12 AMP, 1.5 HP pump for my above ground pool remained in the receptacle when I unplugged it. I replaced it with a new 15 AMP cord from ahome improvement store. Is there any problem with the fact that it's 15 AMPs and the pump is 12 AMPs? It is working, but I think it sounds a little different than it did before I replaced the cord.
Thanks for your advice!
joed 04-19-2009 06:49 PM
You will be fine if you replaced the plug with one of the same configuation. Are the prongs on the new plug the same as the old one?
LeeAmes 04-19-2009 07:09 PM
Yes, they are the same - thanks for your reply!
PaliBob 04-19-2009 07:20 PM
If the cord and plug are not warm to the touch when the motor is running you should be OK
Speedy Petey 04-19-2009 07:29 PM
Remember, the cord MUST be #12ga to be code legal. I am sure there are other code issues as well.
How old is this installation?
LeeAmes 04-19-2009 07:40 PM
Thanks for the replies!
The cord and plug are not warm to the touch and it is #14ga cord...
LeeAmes 04-19-2009 07:42 PM
And the installation is less than 3 years old.
Yoyizit 04-19-2009 08:21 PM
How long is the cord?
LeeAmes 04-19-2009 08:25 PM
It's 10 ft
handyman78 04-19-2009 08:30 PM
Do you need to have it 10 ft long? 1.5 hp is a powerful motor to be on a cord- especially a long one. I would want to have the shortest cord that could reach the outlet without any problem. Also, as mentioned before the cord should be at least 12gauge.
LeeAmes 04-19-2009 08:35 PM
that's a good point. It is 14 gauge -- sorry for the stupid question, but is that enough? I don't know if 14 gauge is more or less than 12 gauge in terms of electrical capacity.
I can make the cord shorter -- I had to put the little connectors on to attach it to the pump. Should I take it off, cut it down, put the connectors on and re-attach? The pump is only a few feet from the receptacle so it doesn't need to be 10 ft long.
Yoyizit 04-19-2009 08:45 PM
12A through 10' of #14 = a 0.5% voltage drop, but I don't know how much more voltage you lose with plug/socket contact resistance at each end.
hayewe farm 04-19-2009 09:55 PM
Why did you replace the cord instead of just replacing the plug?
And why would it have to be a 12 ga. wired cord for 12 amps? 14 ga, cord is rated for 15 amps.
Scuba_Dave 04-19-2009 10:08 PM
How long was the old cord?
I seem to remember a Max length - 6' on cords for pool pumps??
Do you still have the old cord - see if you can read a wire gauge off of it
12g = 20 amps = 2400 watts
14g = 15 amps = 1800 watts = lighter duty
Your pump pulls 12a (Max?) = less then either of these
BUT, sometimes they want a heavier duty cord due to the length of time a pool pump is usually on
My pool pump was pulling 18.6a Max by the rating on the pump
So I hard wired it at 240v
Is this pump on a timer?
That is required here
Scuba_Dave 04-19-2009 10:12 PM
Except that the current installation could violate code & Mfg recommendations
